WestCoastComet
Active member
Hey everybody, I'm Scott from Los Angeles. I'm new to the forum.
I am currently working on getting my 1972 Mercury Comet's 200 ci put back together after a valve job, new cooling system, new lifters, new pushrods, new rocker shaft, cleaned pan, etc. I thought I had primed my oil pump enough because my dummy light said there was oil pressure. However, when I fired it up, I could hear all of my lifters clacking and my purshrods jumping. So I shut her down and thought "why is there no oil still?". I did not soak the lifters in oil, just lubed the exterior heavily with lucas oil assembly lube. However, I thought the priming would fill the lifters.
How long are you supposed to prime with a drill on a six? How long should it take to get oil to the top end? Does anyone think I messed anything up? I ran her for about a minute. She ran in perfect order other than the clacking from the lifters. Good timing, good ignition of the charge, etc. Overall smooth running, but noisy. Any ideas or insight into this would be appreciated. Thanks.
