WestCoastComet":2lmhlh6o said:
Oh, I just thought that if my ex. valve didn't have enough lift it wouldn't be able to get rid of the spent charge fast enough and either dirty up that piston or mess up the valve or something.
It sounds like a single component. It's not the same as when they all had no oil. Just one of them, I think.
What do you guys think about converting to adjustable? Is that a band-aid fix to a much broader problem that needs to be addressed? That is, if we were correct in assuming it's a lifter or slack issue.
I think converting over to adjustable is ok.
I also think if only one lifter is the culprit changing over to adjustable will not resolve the issue.
I also think if you are using the original cam or a new cam, and if it has failed on any lobe
All the money in china will not bring that cam back home.
If this issue falls on the cam the only solution will be to replace the cam.
I just ant ready to go there yet..
For the moment I will eliminate the head, push rods, rocker assembly and all lifters except one….
If it was me, I would confirm which lifter is casing the noise by fallowing the tedious procedure outlined above.
My thinking fallows: The car ran great for an hour or so then the noise came after the engine cooled and the oil settled back down.
Possible causes:
Dirt in the oil ports
Bad Lifter
Possible Solution:
Remove the noisey lifter and confirm it is ok.
Remove distributor and prime the engine again to confirm oil is reaching that lifter and rocker arm..
This can be messy, but you can use a long screwdriver: Place the handle end to your ear and place the metal tip at various points along the rocker assembly.
When you get to the noisy one you wont have any doubt that it is the culprit.
Just use caution, it is fast and easy to trace noise this way.. Except here you will loose some oil..from sling
