Evening guys.
Working on this car, replaced the third head freeze plug from the front (as it was the culprit on the original coolant loss issue), got virtually everything back on and filled the coolant system back up and realized I needed to clock the alternator housing to make it easier to wire up once it was on the car.
Got that all done, and leaned over the car to install it and noticed that the block was wet back by the plug, leaned in there, took a pic and realized that the plug was still leaking. Pulled it all back apart and replaced the plug again. This time I filled everything back up before installing the exhaust manifold and AC compressor. Yet again it appears to be weeping.
Absolutely none of the other plugs I replaced are doing anything but sitting in the block happily.
1) Part number I'm using is Fed Mogul 381-9028
2) Is there a part number that is barely wider in order to seal better?
3) Is there anything else that could be causing that plug to weep?
Second verse, same as the first
On the same car, has a hot air choke, of course the choke tube is about 5 inches of 1/4" ID copper tube, good for pretty much nothing. What material and diameter tube do I need to use? I cleaned off one end of the existing copper tube and found that it's barely too wide to fit in the hole through the manifold. Wondering if a steel 1/4 tube will be thinner and will clear the hole.
Also, it appears that the actual choke is all carboned up, any particular method of cleaning that out?
Thanks guys
Thanks guys
