In this build there will be a need for room for an itercooler and the idea came to me that i could mount the cooloing radiator remotely
Rock buggies do it. Why not me?
here is the logic.
the grill is a crowded place. if i removed the coolant radiator i would have more room.
As a side note, In a different project running concurrently, I am putting a cummins in a Ford where space is a matter of real concern.
On this f350 i have no fuel tanks and the entire space between the frame rails is open due to not having fuel tanks there.
its well protected and its big enough for a dozer radiator.
The other place that might work is the space between the cab and the flat bed. in this location i can cut holes in the headache rack down low, mount electric fans and pull air through the warmed air serving to heat the propane tank Which especially on cold mornings suffers from low pressure to move product.
QUESTION:
With large enough cooling capacity ( dozer radiator) do i really need forced air or even fans?
i would of course mount electric fans , thermostatically controlled on top of the flat radiator.
the radiator would lay flat would that change anything?
I am not crazy though it may seem that way....
here is the logic.
QUESTION:
