My new harmonic balancer arrived last week (oddly enough on Thursday, the same day my daughter was born
). So I'm hoping to do the replacement one day this week. I've been searching/reading here at the forum to see if there are any pitfalls and/or other items I can replace while I'm in there. As best as I can tell, this is all that I've found:
1) replace belts
2) replace timing cover seal
3) remove radiator to gain enough clearance for the balancer puller
But I have more questions:
1) do I need to drain the oil to replace the timing cover seal?
2) can I possibly do this replacement without removing the radiator?... or is the PITA factor greater with the radiator in? (I'm all about reducing/eliminating as much of the PITA factor as I can.)
I plan on removing my a/c pulley first, cleaning the face of the balancer, then hitting the bolt with some pb blaster and letting it sit overnite. Any other hints about breaking loose the crank bolt? (I know an air impact wrench would be nice, but I don't have access to one).
Also, IIRC the crank bolt is the standard "righty-tighty lefty-loosey." I read that some have been able to break the bolt loose by putting a breaker bar on the bolt then bracing it against the frame rail, then bumping the starter (I won't forget to pull the coil wire). If my calculations are correct, I want to brace the breaker bar against the passenger's side frame rail (as the crank will rotate clockwise, the bolt will be moving counter-clockwise relative to the crank).
Any other advice, pointers, provisos and/or caveats would be greatly appreciated!
Bengoshi2000
1) replace belts
Bengoshi2000
