No I don't think so here is Some directions used for cleaning a Pool
Add 1 gallon acid to 1 gallon water in a flower watering can (Always add acid to water, never the other way around). Wet down the wall with a hose. Keep the hose(s) running at all times, without a nozzle on it. Pour the acid/water mixture down the wall, from top to bottom, one 10 foot section at a time. Do not allow the acid to sit on the plaster for very long. Usually 30 seconds is long enough. Use an acid brush to scrub the surfaces and move the acid around. Rinse quickly and thoroughly.
Make sure acid is rinsed completely, as it will continue to etch the plaster. Also try to prevent the acid from wearing a channel path from shallow end to deep end. This can create a worn stripe on the floor.
If the 50/ 50 mixture isn't strong enough, you can increase the acid strength or the hang time (before rinsing), or scrub harder. Usually pools are acid washed twice with the same strength mixture. Remember that you don't want to damage or "burn" the plaster.
After the acid wash, the bottom of the pool will be filled with a foamy, acid puddle. This needs to be neutralized before pumping out. Use 2 lbs of soda ash per 1 gallon of acid used. Broadcast the ash over the puddle while stirring with a pool brush on a pole. Use a small submersible pump with a hose to pump out the remaining acid water. Be careful where you pump it to. Even if properly neutralized, it may destroy plants or kill fish, frogs, etc. Rinse the bowl again, and re-pour the bowl of the deep end to clean up well around the drain, being careful not to burn the plaster too much.
Don't rush the job and be safe. The fumes can be very strong, and very dangerous. Be sure to wear a respirator that will block muriatic acid fumes, goggles or safety glasses and protective clothing. Wear old shoes, or rubber boots. Spray off before exiting the pool. Transporting the acid from the store to the house can be hazardous also. Secure the load in the vehicle. Always have a second person nearby when acid washing the pool. If acid drops enter the mouth or eye, rinse with the hose for 15 mins, without a nozzle on it. Acid on the skin won't usually burn too much, just rinse quickly, for 30 seconds.
