Seems the 2300 is the way Im goin, probably a 500cfm, but will it be ok on my NA motor with the mods Ive done so far? I think it would be, but you all are the ones that would know!!!! Let me know before I lay down the money on a new carb.
The stock 200 may be a little over supplied by the 500cfm carb. It won't be as ecomomical as a 350 carb. If you are trying to have a seamless transition or 2 or 5 year plan, then I'd go 350 Holley. On a 250, I'd go 500 cfm right away. The 350 has great economy, and is the ideal size for a 200. The Schjeldahl brothers at Falcon 6 Performance have affirmed that the Autolite is one of the better 2-bbl carbs, but that any increase in carburation is good. David and Dennis focus primarily on the ideal airflow based on the relative sizes of the existing hole in the head. No point in having 350 cfm going down a 1.5" hole, but a 1.75" log will really enjoy a good 350 cfm carb.
The December 2003 issue of the Hot Rod mag has all you need to know about turbo sizing and carb airflow demand.
Heaps of info on how to size your ricer or V8, nothing much for sixes, although they do have an awesome sizing chart which affirms TO3 60 turbos for most of our sixes. There are a few really helpfull formulaes for help on sizing your carb by the total airflow.
The latest issue has the formulae, while the online additon doesn't. That's why I spend 12 NZ dollars getting Hot Rod magazine. Truley the neatest souce of Americana bar FordSix.Com and Car Craft.
http://www.hotrod.com/techarticles/engine/113_0312_turbo/
Formulae One
Boost Ratio is (psi turbo pressure*14.7)/14.7
10+14.7 = 1.68, (before the loss due to air heating is taken out)
14.7
Formulae Two
The air flow required (in lb/min)is the boost cfm *0.07
eg. A 200 doing 5500 rpm with 0.85% VE needs 318 cfm, or about 200 hp net. With a 10 pound per square inch turbo boost, thats a 1.68 boost ratio, or 534 cfm theoretical. Enough for 333 hp net, or 374 hp gross. Thats 543*0.07, or 37.4 pounds per minute of air needed.
Formulae Three
eg 37.4 lb/min = hp/10, or 374 hp (gross, at the flywheel). Note this is for sizing a turbo or carb. It doesn't mean thats what its going to produce.
So if you could swing 10 lbs of boost, the sizing is that you'd need carbuartion to match the power potential. A 500 cfm 2-bbl carb is proven to be able to deliver 350 hp on a 289 V8 with the right cam.
Go for a 500 cfm 2bbl carb! It simple, cheep, and a 4-bbl wont fit a log head easily due to the porting and close poximity of the log to the rocker cover.
All other info can be got from here.
http://www.turbofast.com.au/TFmatch.html
Read up on this, and then plan you own attack. Like a lot of things, its better to be able get some info, mill over it, and then use your own judgement. Air flow is very theoretical, and it confuses lots of use. You don't need to understand
everything, but you do need to know whats
important.
