Using a drill to spin the pump, has verified that the pressure side of things is probably OK.  I would guess the drill spun at a lot less than 750RPM.  On a cheaper drill, 200RPM is more likely.
What if the suction side of the pump was drawing air at motor speed (as opposed to "cold cranking" speed)?
