Just use a nail or something to drive the spring pin out.
Does the hex on the bottom of the distributor look worn? This just happend one day while you were driving - right?
Make sure the shaft is the same size as the distributor. I am not familiar with the oil pump on these motors, is it possible that the shaft has fallen down into the pump more than it is supposed to, causing it not to engage the distributor ?
Some way or another, your shaft is not engaging the distributor. The fact that it previously may only be the result of it not setting down in the oil pump all the way for some unknown reason. At some point, it dropped the rest of the way down...
Good luck.
Good luck.
 . It was the shaft that came out of the engine, and at least since '75 when my granddad bought it, that's what has been in there.
. It was the shaft that came out of the engine, and at least since '75 when my granddad bought it, that's what has been in there. ).
