I suppose that is possible. When I first rebuilt the engine 11 years ago, we shaved the head .060 to bump up the compression ratio. When the engine was rebuilt again last year, I have no idea if the machine shop decked the block or shaved the head to true it up. I did not request either to be done, but it may have been done as SOP.
I am assuming that doing either just to true up the surfaces would not be enough to raise the compression too high, but in combination with the original head work is it possible? Also, I did not supply the head gasket so I will have to assume they went through normal channels and got the thicker more readily available gasket.
I am running regular old 87 octane right now.
Will the compression test I am going to run validate that the compression ratio of the engine is high enough to require premium?
I won't have time to test the timing mark tonight, but plan on doing it on Saturday.
