cfmustang":2es0tp9t said:
Thanks, everyone.
I removed the plugs, but didn't unhook the battery. Just curious, but how does that make it easier to turn?
No Unhook the battery ALWAYS... that is silly... DISCONNECT the battery...
(pulling the plugs releases the pressure on the pistons, so when you crank through the compression stroke you will smell lovely gas coming out of the plug holes - if the plugs are in tight you will have a hard time cranking by hand... I cannot turn mine at all with them all the way in)
I remove the plugs and use an old torque wrench with a socket on the bolt in the center of the crank. There is just enough room to slip mine down between the radiator and the flexfan, but it is much easier with the fan removed. You want to stand over the engine and turn the crank while you can watch the number one plug hole and stick yer nose in there for a wif of fumes on the stroke.
My biggest problem that no one has really explained yet is why I have to set the idle screw all the way in to get even 900-1000 RPMS idle? Is it because my initial timing is too low? Should verifing the TDC mark and advancing it to 16 allow the idle screw to be where Weber it should be when setting the idle (1 to 1.5 turns in from where it just starts hitting the arm)? Is that what is causing all the engine shaking and mixture issues (i.e. someone mentioned running in the primary circut when it should be in the idle circut)?
are you talking about Curb Idle Speed or Mixture? when you say Idle screw? I am confused?
My story:
http://fordsix.com/forum/viewtopic.php? ... highlight=
Some good advice on tuning with the vacume gauge:
http://fordsix.com/forum/viewtopic.php? ... ge+mixture
as for me, I broke down and took it to my machinist. He adjusted the hex inside the canister for vacume and put in springs to slow things down... but the real problem was the float level.. and the increased rpms... the timing was not that far off mechanically, just a bit crazy on the vacume advance. But I was getting numbers like 20 degrees at 2500 rpms and it was really even less than that... my timing (and I) was retarted in many ways.
once the fuel was running right, the timing came up and fell fairly close to in place and I was able to adjust the mixture screws for best vacume.
Literally 30 minutes in the parking lot with the machinist and then I walked across to lunch - came back and the dizzy was back in the car - we made some adjustments and I drove off... I have not opened the hood except for an oil change in the last seven months.
It runs good now, but can run better. I am working on locking the distributor down and installing EFI with a laptop to control this and dial in the curves on the Dyno... that is starting up to be my summer project.
We'll see!! maybe goodbye carby-carb soon....
