Hello. I'm really hoping you guys can help. My 67 mustang 200 is running very rich. So rich that it is dieing on deceleration and after it warms up it won't really run at all. I have wired the choke open and even switched carbs (1100) to see if it was the carb. I have advanced the timing also with no luck. I changed the plugs today. No help. I have been all through the car. New fuel pump, points, no vacum leaks.
I have no idea what to do next.
I'm thinking it may be a valve issue? The motor has less than 10,000 on a rebuild. Any ideas? I'm stumped. I have been all through the ignition system. It is running very very rich. It has a backfire on deceleration and then dies. Not a loud backfire but the kind that is in the muffler. On deceleration...pop.. pop...pop...then die. It idles fine. It is a manual trans....
Any ideas? Help!! Thanks much...
