1973 Maverick 250/ C4, Holley 5200 on adapter, DSII, 6 into 1 header with Y pipe and dual generic flow masters.
The car runs great....MOST of the time. It does sometimes stall though or slowly die and goes dead while driving. It does this driving along at any speed or condition, doesn't seem to be temperature related as it can happen within the first mile. After the engine begins to stall you can let off and sometimes it will return to idle, sometimes not. If you stop, it will always restart immediately but will stall again in a short distance. It normally does this 2 to 3 times then runs normally again, maybe for a few days at a time. Any ideas? It has a new carburetor that runs great, new fuel pump, rubber lines, fuel filter and new plugs. It does it with or without the gas cap on. I've blown out the tank vernt line, etc. All of the ignition components were installed "used" from a donar car and have previously given good service.
Could this be ignition related eventhough it "feels" like fuel?
Thanks for any help guys.
Brad
Brad
