Here's the scenario. 1982 Cougar wagon with 200 six and all functional smog equipment.
Start the car in the morning. Runs great. Let it sit for 5 hours. Starts immediately but stalls at idle just as if it has a vacuum leak. Start/stall, start/stall. This goes on until it warms up then it's fine.
It acts like it needs to be choked but can't due the the ambient temp. Acts like it's very lean until it has been running for 5 minutes then all is well.
If I let it sit for two hours it's fine. Over three it acts like this. Over 8 all is well.
The ambient temp is close to 100* by 11 am. This is strange and has been doing this for the last couple of years and has been the same for the last three carbs that I've had on it. I'm convinced that it's heat related but not due to excessive engine heat. The choke is an electric type that has the vacuum pull off dashpot. All is adjusted and measured per the Motor Manual. The carb is not water cooled nor does the choke have a water connection like some 200 ford engines. All is well but of course the choke won't set with outside air temps that high. The odd thing is that five hours from now I can go home and the car will run fine. The difference is the car is parked in the garage out of direct sunlight. The garage is typically over 100* at 4:30 pm.
Any of you Ford 200 six owners experienced something like this?
The car has never exibited any vapor lock symptoms while driving but I'm wondering if maybe the fuel line is heating too much out in the sun even though the engine has cooled down. The ford six guys here know that the fuel line is routed well above the intake manifold and nowhere near the exhaust manifold although it's above the exhaust manifold by at least six - seven inches.
I'm really confused on this. I drove it down to the Fab Fords show in April (165 miles) with no problem at all. It was hot down there and it had a lot of idling time due to traffic leaving the show and it idled a bit rough in the stop and go but didn't stall. It seems that it has to sit for a few hours after running for this symptom to occur.
