Step by Step Assembly guide for putting my 58 223 back toget
1958FordF100
http://www.1958fordf100.net--------------------------------------------------------------------------------
I have all my machine work done and am ready to reassemble my 1958 223 inline six. I want to put it back together myself. This is a first time for me. My machine shop has given me some pointers. I have a" how to rebuild your for small block book" that is helpful but Is there a step by step guide you can recommend for me to help with putting an inline six back together? Or a Youtube video ect that would help a first timer like me.
Or is there a thread on the forum I have missed?
I have done a number of the 223's nothing that’s too big of a deal is an easy engine to work on. Cleanness is number one thing you want to really clean the bores to get rid of any grit from honing and run a bush in all the oil passages (like gun cleaning kit) solvent gun and blow it out with air until is clean. Back when they only had hot tanks use to clean every thing with solvent then wash with tide rise off blow dry with air coat it with WD40 and oil the bores, think the jet cleaners do a much better job. You would do mostly the same thing for any engine and your shop might have done most of that for you. The 223 did become known to have problems with clogging oil passage through head that would end up starving the rocker arms warring them out the Y Block V8’s had this same problem. They sold a lot of the external oiler kits to fix this problem on used engines. The small passages along with some of the older oils and the fact that many people did not change the oil frequent enough was probably a bigger contributor. The new detergent oils fixed keeping the sludge out, new problem is some think there is not enough zinc to keep cam and lifters from ware this something I have been thinking about. But even so sometimes these passages just are not clean enough after coming back from mach shop. If it went there with a lot of visible sludge good chance there still could be crude in them. If you are using the rope seal in rear main you have to make sure that it is seated properly trimmed right will be same technique as on a V8 Y block of the era. I always torque down the bolts mains rods heads in three steps. Most books show correct torque spec but have found the wrong data on Ford engines in one. Good luck they are great engines.
Yeah, step one, clean everything. Start with the work area.
Step two, repeat step one...
When you get to step twenty-three or so, and get to start putting stuff together,..
Go get an engine bag. They're occasionally made of black plastic and used inside garbage cans. Unless you have large clear bags around... You want to be able to keep this thing slightly cleaner than a hospital operating room if you take a break during assembly.
Look everything over. Every oil hole in the crank (flashlight helps) and block. Shoot 'em with solvent or carb cleaner. I know your machinist cleaned it. So what. Even when I was the guy who washed the block/crank/etc. I still checked one last time B4 assy. Ten minutes WELL spent.
Bag all the parts you've cleaned (crank, rods, pistons, etc.).
I use paper towels and WD-40 to check the bores for any grit/dust left from honing, handling or storange. Then chase any lint from the paper out with a VERY clean hand and more WD. Check the cam bores for contaminant with a finger and WD.
Once that's done, I'd grab the rings, and check them ALL for correct gap. One-by-one. Yes, it's tedious. But a butted gap will RUIN your day.
I personally believe in buying gap-to-fit rings. But even if you get the ones with the 'big enough' gaps, check 'em.
If you're putting in your own cam bearings, do it now.
If there is a cam plug (like a freeze plug) at the back of the block, it's time to install. Smear the outside with a SMALL amount of sealant on the corner between the flat of the plug and the diameter of the edge, so that it will drive in and have a tiny little bead of sealant when you get it put in.
Now, put in ALL oil passage plugs. And ALL water passage plugs. If you have the sending units, you can put 'em in now, too. I like teflon tape on tapered threads. Some guys like teflon goop, other guys like other stuff. Personal preference.
Drive in all the freeze plugs. I like a little bit of GOOD quality silicone smeared in the bore when they go in. If there's a pit or imperfection, it can bail ya' out.
Now, take a coffee break, then check for ANY holes left open. Is everything plugged that should be? I'm a believer in getting them ALL done at once if possible.
Next step, grab the cam (which you've already cleaned, right?), put some lube (motor honey is good) on the journals and get the longest bolt you can screwed in the front of it.
If you're able to stand the block on its butt so you can drop the cam straight down, that's best. But if you can't, then get the block oriented so you can get one hand under the cam inside the block to guide it as you put it in. You DON'T want to gow up the journals, or you're going to go backwards. DAMHIK!
Cam is in and spins free, right? Great! If not, find out why. It won't 'faith heal'.
If the engine has a cam retainer plate, put it on at this time. Red loctite on the mounting hardware.
Now it's time to put the crank in. Well, actually the main bearings; the crank comes along a bit later...
Before putting the inserts in, run a CLEAN finger over all the journals in the block, and along the sides where the thrust bearing will go. Last chance to find any dirt, chips, or burrs before they cause grief.
When putting the inserts in, I rub a CLEAN finger over the back side to make sure that there's NO lint/dust/debris on the back. If that gets caught between the bearing shell and the block, it's going to close up your oil clearance at that spot. Not good.
Everything good? Okay. Then I put the insert in carefully. There's a kind of a feel to how it should pop in that's hard to break down into words... but I'll just keep typing.
If you feel any 'grit', or 'grind' as it goes in, pull the insert back out and look real close for a little curl of metal cut off of somewhere, or a tiny chunk of grit. You can feel a miniscule amount of dirt if it's in there (think less than a hair in size) - which is still too big! Anything other than a clean 'snap' of the insert into the saddle is unacceptable, and calls for disassembly and inspection.
I like to put the inserts in so that the end with the tab sticks up about an eighth of an inch or so, and slide 'em into position. Personal preference, I suppose, but I can feel if there's a little chunk of crud in there as it slides that last little bit.
Once all the main inserts are in the block, it's time to put the crank in. You did clean it already, and left it in a bag after cleaning, right? Well, pull it out, lube the journals and thrust surfaces with some motor honey, and set it in. Carefully - don't drop it.
Now, get the one main cap with the thrust bearing, and install just that one, torqued to spec.
Take a prybar, or tap the crank with a soft face hammer to drive it to one end. Put a dial indicator on the block, and pry the crank the other way. Measure the travel, and compare to your manual.
If that's good, then you can install the rest of the caps with main bearings, torque 'em all down, and check that it turns easy.
If you're building a Honda, or other new engine w/ a one piece rear seal, pop it in now. Otherwise... pull all the main caps back off. Now, I hear you cussing at me for having you go backwards. There's a reason: if you have any funny feel, you won't catch it with the main seal in. C'mon it's ten minutes' work, and you're good at tightening those bolts now; lots of practice. :)
So, pull the crank out, put in the main seal, drop the crank back in. At this point, I like to use a little anaerobic sealant between the rear main cap and the block. Just a tiny bit; you don't want it squishing out onto the bearing journal or something.
Put the main caps back on and torque the bolts, I promise not to ask you to take 'em back off.
Anyway, the cam is in; the crank is in. Soon, we'll put the timing set in, and then hang the rods.
But that's another day's typing.
-Bill
I check to see that all the oil holes in the cam bearings are open the 3rd has a hole in the top to oil the rocker arms the tube to oil the rockers goes in after the head & rockers are on I have a 1957 ford shop manual from dennis capender it show about all you need to put your engine togather
Excellent posts. This should be a "sticky"! Also, Divco (Milktrucks) used 223's, amongst other engines. Their service manuals have step-by-step istructions for re-building, with photos.They are available thru e-bay.Jim
