72maverick
Hello,
I pulled the plugs after letting the car idle and noticed blue smoke from each cylinder. I know my number 5 cylinder has a bad ring since the compression test was so low and there is blow by from the oil filler and oil level tube. Also, all the small plugs had some oil fouling on them. So can the smoke in the cylinders be from the bad number 5 ring? or is it from the cylinder head?
