Hey guys, my turbo el is in the process of getting a turbo setup, once it's finished it should be seeing around 300 rwkw, fuelling is obviously going to be an issue with this setup and originally I wanted a wolf 3d (or similar with 600cc injectors and a walbro 500hp fuel pump all up just for parts it will cost just over $2k, then there's the tuning of the ECU and installation which will see it costing over $3k for the fuelling alone, after all this petrol will still be expensive!
Now iv'e been thinking about going straight gas after seeing cars like EZY10 and the VL turbo GAS747, it doesn't seem like abad idea. I have a bit of knowledge on duel fuel systems as I used to own a EB on duel fuel, but i'm not sure on straight gas setups, I know i'll need: a throttle body(GRA is all i know of), convertors (from what i've seen the twin GRA B2 setup seems good), lines, tank and an ignition computer.
Now i'm not too sure on how much it will cost all up, I heard the parts alone aren't too expensive it's just the installation that costs alot. I'm confident with installing the convertors and TB etc and could get the tank/lines get done by a pro, I could also get them to check over the rest of the installation too.
So to anyone that has done something similar, how much did it end up costing all up? I wouldn't mind knowing what parts you got etc. I can't get in touch with gas research for some reason I think there site is down or something. What sort of GRA throttle body would I need? I know they have different CFM ratings etc what would be sutied to around 300rwkw? I want more in the future so it needs to support around 350rwkw later down the track.
In my EB I experianced that I would get less km's for the same amount of gas compared to petrol, i'm guessing that it will be the same with straight gas obviously but to anyone that has a turbo straight gas falcon how many km's do you get out of your tank and how big is it? I'm going to try and get the biggest tank possible and practicle
That's enough writing from me for today, i'm sure i've missed out some important points but just ask if you need more information and i'll tell ya's!
Cheers in advanced!
Cheers in advanced!
