I am currently planning to build a straight gas 250 with performance in mind. The below is going into an XE.
Currently thinking of:
larger cam (hydraulic)
valve springs
pushrods
worked alloy head
possibly 200 rods with ACL pistons
backed up by C4 with 3000 stall & 3.23 eb series 2 diff
1. Now, if I were to go the 200 rods & ACL piston combo, will the higher comp version (11.8 from memory?) be ok to run with straight gas?
2. With the higher rev range with 200 rods, what type of cam should I be considering? Durations/lift etc?
3. How reliable will the 200 rods/ACL piston combo be? It wont be seeing 7k RPM daily, but I will definately be hitting 5k RPM daily... stretching it to 7k occassionaly.
4. Rough price of the ACL pistons?
5. What else should I be considering through the build?
valve springs
pushrods
worked alloy head
