Inline6Merc
What would be better on a inline6 200, Supercharger or Turbocharger?
I hate to disagree with my man Slade, but the numbers don't back up his conclusions. Here's a scanned image from last year's HRM's Turbo-Roots-Centrifugal Shootout (all three tests done on the same engine, back-to-back). The advantage in every way goes to the turbo for the critical 2500-5500 street RPM range. Period. Dot. End-of-conversation. A turbo is the easiest and cheapest to install, as well. Install a blower if you like them, but the answer to Inline6Merc's question is unequivocal.CobraSix":3cfkwl80 said:That's like say Coke or Pepsi.
It's really up to you. Both will improve the 6.
I personally like turbos because it's on demand and really doing no harm when you aren't on the gas. But Supers have advantages too.
Slade
CobraSix":1e9lx9l5 said:Boost for Boost, if a SC makes 4psi at 2500RPM and a Turbo makes 4psi at 2500, the power is going to be same except for some small changes in back pressure and resistance from the belt (depending on the induction type).
xtaxi":33t8oqwm said:3. A blow through turbo will suffer delivery problems when the boost goes up.
Sorry, Dan, but UpsideDownTaxi is correct. It has long been known that pressurised carbs have fuel distribution problems at fairly modest boost levels. Remember, a carb does not understand pressure. It supplies fuel by creating a pressure drop across a venturi. If the carb sees a 2 PSI pressure drop across the venturi, it will supply that much fuel whether you are at 0 or 20 pounds of boost. This can cause the engine to lean out at high boost, and can lead to fuel distribution problems as well. That's why blow-thru carbs are generally held to about 20 psi boost max.import killer":b5kz5li7 said:No it won't.xtaxi":b5kz5li7 said:A blow through turbo will suffer delivery problems when the boost goes up.
54Ford":3q2wqw9b said:Sorry, Dan, but UpsideDownTaxi is correct. It has long been known that pressurised carbs have fuel distribution problems at fairly modest boost levels. Remember, a carb does not understand pressure. It supplies fuel by creating a pressure drop across a venturi. If the carb sees a 2 PSI pressure drop across the venturi, it will supply that much fuel whether you are at 0 or 20 pounds of boost. This can cause the engine to lean out at high boost, and can lead to fuel distribution problems as well. That's why blow-thru carbs are generally held to about 20 psi boost max.import killer":3q2wqw9b said:No it won't.xtaxi":3q2wqw9b said:A blow through turbo will suffer delivery problems when the boost goes up.
Yet another reason to go draw-thru...!![]()
