23Afalcon
I have a 1v which was rebuilt professionally for my 1960 ford falcon 170ci, I'm considering switching to a 2v. However I'm nervous to put the money into a switch only to find I should've gone with a weber.... Etc. :help: I would appreciate feed back as to what you guys have experienced.... :thanks:
you're the bomb..... Thanks for the insight.... That's my next project. I just feel like I have no power right now, granted before I started rebuilding this car it sat for nearly 8 years, I have replaced everything externally on the engine, including doing an alt swap to rid the car of the generator. I've done compression test and it's a little low across all cylinders so seems ok, just not too sure what else to focus on, between the weak throttle linkage hook up and the carb????
