Thanks for your Reply. I did loop the two connectors. One plug for the rear backup lights, and the other plug to start the car. I stuck a wire in 1 connector and looped around to the other side of the same plug connector and it did work. Thank you so much.
I've got the T5 transmission in the car. It is hooked up, and it bolted on really nice with the 66 bellhousing and an adaptor plate from NPD. My fabricated, "jig" , adaptor for the 1990. Clutch slave cylinder seems to work good.
I purchase a crossmember from NPD, made by MDL. Nice piece, little more then I wanted to spend, I probably could have made the crossmember but I'm glad I decided to go with MDLs. The shifter fits right into the stock hole in the transmission tunnel. I didn't have to cut any metal, so far, haha...Thanks Modern Drive Line..
Now the drive shaft? I am completely confused what to do. I understand that the stock yoke from the original drive shaft will not work. Can I use the original 66 c4 yoke? I haven't checked,
because I filled the transmission with fluid and I didn't want to fumble around with the original yoke while transmission fluid is pouring out the back of it. Yes, I know, I should have waited to fill it. But, anyway,..my stock c4 6cyl yoke looks a lot smaller.
I acquired an aod yoke some time ago. And it fits right into the T5 transmission. However I don't know what the combination is to get that yoke to bolt on to the stock driveshaft .. My current driveshaft Is for a C4,.. 66 Mustang. 6 cyl.
I did buy another used drive shaft. The gentleman I purchased it from said it was for a 65 Mustang with a 3-speed. He did pull it out of a 65 mustang trunk with a 3speed, however the engine was changed to a none running 302, and the car was a T code c6yl car...However this driveshaft seems to be about three inches shorter. That's odd?
I have two drive shafts, and several U joints.... And I am confused. What do you guys think? What do I do? Please help?
And,..how much play or movement in and out should the yoke installed in the T5 have.Thanks for your help.
