The base number for this Ford starter application is 3157 this is for the old style large case starter used from the early 1960's through to 1983 (end of production of the small block six). With this number you can cross referance it over to the Mini Starters, here is a listing showing all the applications of this mini style starter see the below link.
https://robbmcperformance.com/products/ ... arter.html
Note that Fords have two different starter offsets 3/8 or 3/4 inch as well as two or three bolt mountings. You can figure out the offset by measuring from the face of the starter mounting boss to the flywheel face. Generally the 3/8 inch off set is for a manual trans and the 3/4 inch fits an auto trans. If you want the old style large case starter as an example look for a 1967 to 70 Falcon or Mustang with a 200 six and manual trans (a two bolt).
If you want to go with a stock Ford style mini type starter look for a 1992 to 96 5.0 with a 5 speed trans (also is used on some late 4.9 EFI (300) engines used in F150 pickup with a 5 speed. These stock type starters are quit good and are the ones I have most often used on my budget builds. On my next all out build though I am planing to use the RobbMc mini starter in above link. Good luck
