No, No, No! Moving the rotor inside the distributor will not adjust your timing.damondaysh":3ungkhrv said:By adjusting the rotor in the distributor, will that adjust the timing? Or would I need a professional to do this for me?
You will need a timing light and a shop manual. The timing indicator is located next to the crank pulley (balancer) and can be seen from the distributor (driver's) side of the engine. It is adjusted by loosening the bolt at the base of the distributor and turning the distributor while watching the timing light against the indicator and numbers on the balancer (if that didn’t make sense to you read the manual). If you have a stock setup you should be running 6* behind top dead center (BTDC) for an automatic or 12* BTDC for a manual.
If fixing the exhaust donut fixed your pinging at acceleration you may not need to adjust your timing.
