Centreforce clutches are used in 202 cube Aussie Holden L6's with 8.6" clutches without too much bother. The Toyota light truck stuff is also an option. The Cortina in my profile runs a Toyota HiLux clutch plate with a Ford pressure plate.
Centreforce stuff can be a bit wonky on the balance side, and it pays to use a blanket or scattershield. Weights on the Centreforce pressure plate are okay if your not seeing 6500 rpm. Some catagoires ban them unless used with steel flywheels.
Any more than 5500 rpm, and I'd be looking for a better flywheel. With giggle gas, your finish line rpm and maximum power revs should be lower. With 75 shot, you'd most likely be in the next gear, and should be short shifting well under the previous rev-range with 50 shot. More gas lowers the peak power rpm. Less rpm helps suppress clutch slip if the surface of the flywheel is score free. One trick is the brake cleaner in the throw-out bearing hole at 3000 rpm. Use a long tube, and do some mild clutch dumps. The crap often centrfuges out, and gives you a better clutch surface. Last resort, but may help you out.
