Hello, I managed to get my timing chain switched out. The new chain is WAY tighter so that is good. By the way the oil slinger was in backwards so that may account for the weird wear paterns on the gears. Must not have been getting enough oil?
Anyhooo...so I'm all happy, I have the timing cover back on and I'm sliding the harmonic balancer back on thinking to myself "looks like I'm gonna be able to fire this baby up today (Keep in mind car still has mystery problem to fix)!...NOPE..as I am very gently tapping the harmonic balancer on with a rubber hammer (just enough to get the bolt to thread) I see a little piece of metal fall. Wonder what that could be?
...Well it is a chunk off the balancer. Neat huh? See pics
Can I use this one? There is a bolt that holds the piece in.
Do I need a new one?If so is damper doctor the best (see least expensive) choice?
This is a 2 pully one. I only need one pully. Will this come apart? The part I need is still good...
Also, as an added bonus I had a HELL of a time getting the distributor in. The last one basically fell in. Not this one. I had to sand the base just to get it to fit in the hole at all then it would not go down no matter what. I moved cam gears, I turned rotor, I sanded base, I cussed at it. I think I actaully over sanded it???
Finally after about 2 hours I got it to go. Complete ...PIA. Then I decided to pull it out and check it out a little thinking it would go right back as long as I did not move anything...WRONG. Would not go back?! Finally, after another hour+ it went back. Complete nightmare.
It is official, the car gods do not like anymore...
... But, I will push forward...the saga continues...Sorry if this turned into a rant. I hope you guys can feel my pain.....At this point it is actually funny!!
