A Anonymous Guest Jan 11, 2003 #1 Do you set the timing dots to line up on the intake or exhaust stroke of cylinder #1 at TDC?? thanks much
rbohm 5K+ Departed Member Jan 11, 2003 #3 8) in fact when you line up the dots like the manual says, you are setting the motor at tdc compression stroke.
