I need to run a everyday driver with a 200 cid and the single barrel carb. I think it is a 1100 with the auto choke. I need to set the timing so it will run good or as it should, no racing. and what should I set the auto choke to or at. I have tried to re set it a couple of ways but all seems wrong. I set the auto choke to with the engine cold push the throttle all the way down and release. I set the auto choke to just about closed. The timing right now is at 4 deg. Help
