Bradbutlernc
Well, i took the falcon out today to cruise around to get togethers and whatnot, and it runs great, starts great, etc. But one thing that bothers me still is it has a bit of a rough idle while in drive. Its like it will idle then puff a bit from the exhaust, and keep idling fine then puff a little again, kinda low and shaky idle while in drive only. I assume this would just be the pilot/idle fuel adjustment screw needs to be adjusted out some? Also i plan on checking the timing, what should i look for when i use a regular timing light? Sounds maybe like a vac leak too but i cant find one.
