Hey gang,
I'm still fine-tuning my inline 6 to get the most out of it.
I just added some more back pressure via a new muffler. Prior to this, I have had several glass pack mufflers which were fun but kind of loud. The new system sounds amazing and quiet but a vibration that was a bit noticeable has become more noticeable. I thought it was the clutch/flywheel issue that I would resolve by replacing that with a T5 but now that the engine is quieter, I can notice it more and it happens in gear or out of gear when I just slowly rev from idle to about 2,200 RPM. It begins somewhere around 1800 RPM. After around 2200 its much smoother and not really noticeable.
A few things about the engine:
New build last summer/fall, 1966 7-mains block with about 750 miles on the engine. Crank was ground, balanced, polished. Rods sized by shop and hung on pistons. Block bored 60 over. Static compression ratio a little under 9:1. Clay Smith H-6474-0-B camshaft & Clay Smith hydraulic lifters, OEM springs, OEM valves and rockers. Degreed to match cam card within a degree. HEI ignition. Header. Weber 38/38 on small log. New PCV valve, closed circuit into a catch can and into the log below the carb.
No leaks, no blowby, no oil burning, starts easy, revs quickly, plenty of power, no back firing ever, break in was a breeze. The carburetor is a Clifford/Redline carb configured for the ford 6 200 and I have it dialled in for the best lean idle.
Some ideas:
Cheers,
Andrew
Some ideas:
- I can detect the vibration or shake any time I rev the engine slowly of quickly, whether it's under load or out of gear, clutch in, clutch out.
- I advanced the initial timing to about +24° and it is noticeably better but that seems like a lot of advance. My vacuum advance is +10° on ported vacuum. If I had a higher compression ratio, I'd be worried but I can't detect any detonation knocking. I will call the Clay Smith tech line tomorrow to see if they have a recommendation for initial timing and curve for that cam for my compression ratio.
- I've found that the idle jets on the 38/38 have a significant effect on just off idle response. I was running 60's for a while but thought it was too rich and recently went back to 55's. I will put the 60's back in and adjust for best lean idle and see if that improves it.
- I've read that sometimes by mistake a transmission shop will balance the flywheel like a small block ford when they surface the flywheel and that will introduce a shake that matches my description. I will be replacing the transmission with a T5 and plan on having the flywheel surfaced and checked for balance when I can find a shop to do that.
Cheers,
Andrew
