Add a 4th to the list of Mech_E!
The 11" clutch bolts right up to the stock flywheel. I had slipped the stock 10" a few times and decided to replace it with the 11" when I rebuilt the engine. I have never had the 11" slip. When I pulled the M5OD I also removed the shifter cover to inspect the gears. The input shaft gear had begun to gall - that transmission had pulled a lot of cars and still drove fine.
My WG actuator is from some little Garrett, I modified the Holset WG bracket to hold the actuator since the rod is shorter.
Back in the spring I picked up an old Logan 10" lathe and spent the following months cleaning, and painting it.
Of course then I needed something to make on the new tool, and with EDIS I didn't need a distributor any more.
There are bronze bushings to support the shaft, brass washers on the top and bottom to take any thrust, and cross drilled to pick up the oil from the distributor oil port.
Nice machining job!
![20160426_180214[1].jpg 20160426_180214[1].jpg](https://fordsix-data.xenforo-hosting.com/attachments/0/372-9cd586e74324f5eb84fe32a1c29de118.jpg?hash=nNWG50Mk9e)
![20160426_180244[2].jpg 20160426_180244[2].jpg](https://fordsix-data.xenforo-hosting.com/attachments/0/371-6806229081b5702e51b00bc8d60b2169.jpg?hash=aAYikIG1cC)
