Beemer+ford6lover":1mba85dv said:What he has done is pretty much mimic a factory boost set up if ford had ever made one. To bad they didn't
Beemer+ford6lover":3rezmnr4 said:Its not really all that uncommon especially for factory turbo cars, the engines are designed to work within a set amount of rpms so the heads flow charateristics are set to best match those operatinf parameters. So when you really need the extra go they would squeze a couple extra psi of boost. But the engines won't survive sustained use at those rpms cause they are designed for that. Just periodic splurges into that extra boost. What he has done is pretty much mimic a factory boost set up if ford had ever made one. To bad they didn't
Beemer+ford6lover":2n1y9ubr said:None of the manufactures actually claim its being used, but i have looked at plenty of boost mapps from cars on the dyno, like mitsubishi evo's, subaru sti/wrx's, and even with my rx-7.
Turbo_B":2pkw04qj said:Truthfully? Holsets are cheap and durable! The guys on the dodge truck forums sell their stock ones for not much money.
For this engine, you would not want a smaller turbo, gasoline or diesel based. I had a smaller turbo, made great power off the line, but also wanted to make boost on the highway and it made a lot of noise because of this.
I will never use this turbo to its potential, it will support a pressure ratio far greater than I need. But, its spool characteristics align with the rpm band that this engine is used in and so I chose to use this turbo.
