Sorry about not getting back to you guys sooner, but I just spent 20 hours staring out the front of FRED...
And since I'm 13 hours away from home at 500 MPH, I don't even really care that it's 2 o'clock in the morning on Christmas Day...
Duane, I really didn't know you if had a Mustang. I don't recall if I just presumed you did or whether I looked at your avatar and my brain filled in "69 Fastback"...whatever!
Anyway, Mustang or Maverick, the idea's the same.
And no, cfmustang, nothing is ever that easy or that cheap.
In fact, a close examination of the photo will disclose several oddities. First, that's a Ford 223 engine - I reversed the photo to illustrate how a simple turbo setup would look on a 200 or 250. Second, that's a Weber or Holley 5200 carb, not a Rochester. And lastly, that's not a Buick turbo (I think it's a Rayjay). This is a scanned photo from an old Ak Miller setup from about 1971.
However, this is very similar to what an actual Buick setup would look like. I know because I have two of them. And yes, the Buick is a draw-thru. It uses the Quadrajet off a 455 Buick...I think someone told me it's an 850 CFM carb. In any event, because it's a draw-thru nothing special has to be done to it. One would want to fab up an extra support mount (not shown in this photo, but a real good idea, and easy to do). Also, look closely and you can see that there is an oil line snaking over with the other lines to feed oil to the turbo bearings, and there is a drain line back to the oil pan. I'm sure there'd be some fiddling to do with vacuum lines, etc. Eventually you'd want to recurve the dizzy, or add a boost retard, but that's about it.
Of course, you would want even more power, so eventually you'd start digging back into it, but that's another story...
Gotta hit the sack. My Grandson says Santa Claus is coming later...
