Hey guys I need to build a engine for my turbo EL with the tickford motor from what I have gathered this combo seems to be pretty common:
-ACL race series rebuild kit (the EA version)
-Balanced Crank
-Crack tested/Shotpeened stock rods
-ARP rod bolts
-Machining top of the piston to get compression down.
-AU head gasket
The head will be ported by a mate that works in the industry, i'll be getting harder valve springs, cam to suit turbo etc...
Is it worth getting it O-ringed?
What sort of power should a set up like this handle? According to my tuner I should be pushing close to 300rwkw later down the track I want even more, would the engine be fine with it if I keep the revs below around 5800rpm?
Any other suggestions?
Cheers guys, i've been reading the forums for a long time now, just regestered today.
-Balanced Crank
-ARP rod bolts
-AU head gasket
