Howdy,
1. weld a bung on the exhaust pipe closest to the turbo for an O2 sensor for the air/fuel ratio
2. boost will read directly after the compressor so tap a barbed brass fitting into your intake tubing before the carb.
3. boost is controlled via a wastegate (internally or externally) depends on the turbo you get.
4.Will's exhaust maniflod is homemade.
5. cast pistons are fine even up to 18 lbs of boost and your CR can be controlled via different head gasket thicknesses, plus different dish type pistons.
6. the 272 cam is fine, some have cammed up to 280 list that they are using.
7. the 350 holley is a fine carb to use, take off the choke assembly, mill the choke horn and block the choke rod hole with jb weld, install a solid float and the correct jetting and Power valve and your basically done.
8. ignition goes both ways, and you don't want a hotter spark in case of the turbo...DENOTATION at higher rpms! run a colder plug and can even reduce your gap alittle. you can use a timing retard device like MSD (for electronic ignition), or not use vacuum advance relying on centrifical alone, or use a advance/retard vacuum canister off the dist.
9. don't forget about the BOV to release pressure when coming off the pedal (like shifting)
10. to give more boost you can get a boost controller that limits the pressure going to the wastegate. can make them yourself or buy them.
it is simply an adjustable relief valve that is spring loaded.
11. fuel needs to be boost referenced, also. you can do this to your stock fuel pump by running a boost referenced line to the atmospheric side of the pump (which will raise fuel psi when boost is on) or go electric pump with a boost referenced and return style fuel pressure regulator.
12. your exhaust needs to be free flowing with minimal backpressure (some is good for the low end)
13. and make sure the rest of your drivetrain can handle the turbo.
Hope I did not forget anything and Good Luck!
Kirk ' 73 bronco
