Howdy fellers,
Last night got the engine running really, really good. I ended up starting with 68 jets, then to 65's and ended up installing the 61 jets (which came with the 7448 carb), at idle it is on the rich/almost stoich of the A/F meter. I have the orange pump cam in the #2 position and a 0.028" squirter and a 8.5 PV. I am still taking it easy (gun-shy from blowing 3 head gaskets already) at least until I get some break-in time for this engine.
I turned down the boost, now at almost 5000 rpm I am seeing @ 10 psi from the bonnet, and I set the timing at 8* initial with a total of 26* at 3000 rpm (and no vacuum adv). The engine runs like a top and I have not been this excited in a long time, last night was a good night (had to celebrate with an evening cocktail, well two or three)! You can drive normal or romp into it for some fun...now this is where I begin. On the A/F meter I am getting a lean situation when I get heavy into the boost. Should I start at the PV and go to a 10.5, or drill the pvcr's bigger, or change the size of the high idle bleeds? When I got on it up to 5000 rpm, the A/F meter went off scale to the lean side, so I do need more fuel. Don't forget at idle I have @ 19" Hg, that's why I say the PV first.
Anyone have any recomendations?
Kirk
