Two Motorcraft 2150's
I'm looking at installing two 2150's (1.08 each.). Where and how is the best place to mount them? Adapter? Directly to log?
Need some advice.
I think mustang geezer played with this before.
I'd cut part of the top of the log off such that you can make an adaptor plate to position 1 carb centered on #2 cylinder and the other centered on #5 cylinder with the carbs mounted transversely.
Slade
I think you're right about Doug but I believe he used two YF's. Now the only thing is linkage. Sould they both work in tandeum..hmm...I guess that's the only way, unless I used three 2150's. :roll: Modified Offy, maybe? 3x2 instead of 3x1?
But then again, that would be over kill for my setup.
I just wish I could use my 4180, that would be nice. 8)
