I'm a traitor and swapped a v8 into the Falcon, could not resist a free engine (ported E7 heads and 1.7 Roller Rockers) / transmission (AOD). Anyways, I had tightened down the roller rockers whenever there was not oil pressure to pump up the lifters. Now there is pressure and a smoke is coming out of my exhaust. I'm 100% sure it is not oil as it does not smell one bit and seems to burn my nose after a minute which leads me to think it is fuel. Would the method in which I had adjusted the roller rockers when the motor was dry make it so since they are pumped up the valves are staying open too long and unburnt fuel is coming out of the exhaust?
I still have the F150 with the 300 so I'm not that much of a savage.
...Forgot to mention. The engine revs up to 5 grand without a hitch, other than it backfiring a little bit after the gas is let out but I'm thinking that is due to the problem listed above, don't really dare to go any farther than that.
