Howdy cmm:
And welcome to The Forum.
How about some more information about your car. How old are the spark plugs? What number cylinders are they from? How is this car driven? Lots of cold starts with very little warm up?
What I'm saying is that it may not be a valve seal problem. Other more simple issues should be explored first. Starting with the questions above. My kids drove a Mercury Comet, 250 with an auto trans, back in high school. It was started up and driven about 2 miles from home to school. Then started up and driven to soccer practice, then work. The point is it never got really warmed up to the point of burning off chamber residue. Result- fuzzy spark plugs. So we ended up cleaning or replacing spark plugs about every three months. We used .035" on the gaps with the stock point distributor and coil. The auto choke worked great even in below freezing mornings. And it never smoked or used any oil. They could have driven it 20 miles every weekend to burn off the fuzz, but they had to pay for their own gas, so that was out. So a ritual spark plug cleaning became a daddy-daughter event. Every other month was my sons turn for some bonding. We also used this time to assess fan belts, fluids, change filters and oil, and just talk.
But, I digress. So, if any of this sounds familiar to you, do some more assessing before concluding you need new valve seals.
On your ignition, why are you interested in keeping the stock specs on the plug gap? I'm assuming that the reason for upgrading to a Petronix Ignitor and coil was to improve mileage and or performance. Or possibly to eliminate points maintenance. All good rationale.
But, with an improved ignition you can gain even more by opening the spark plug gaps to .040" or .045" with no increased wear or any other downside. And you can gain more in power and economy by increasing the initial advance setting to 5 degrees more than the stock specs call for. For example, if the stock setting with an auto trans is 12 degrees btc, try setting the initial at 15 to 17 degrees btc. Listen for any pre-ignition knock. If you hear any reduce the initial advance setting by 2 degrees and try it again.
Again, welcome to this Forum. Great people here and willing to help and offer suggestions.
