Why isnt this more popular. Does anyone know if it has any bad side effects like rusting the exhaust system inside?. If the claims are true it must be good (for running higher comp etc). They give no idea what compression can be run. Has anyone tried it with a Ford six? Would anyone like to take an educated guess at what comp could be run?
Does increasing comp ratio from 9:1 to 10.1 increase power 10 percent, how do you work out the increase?
I was thinking about the option of running the higher comp ACL pistons for the 200 rods. I know the dished ones were 10:1 comp and the flat tops 11.0 something. Might be worth doing if I could run the higher compression with the water.
