Gearhead138,
According to The Ford Falcon Six Cylinder Performance Handbook, the 144 had a 1.00" venturi 1 7/16" throttle bore for 130cfm. I think the carb you have can achieve near 300cfm. If you want a progressive 2bbl, And who doesn't, I would look for a Holley/Weber 5200 off a 78 Ford 2300cc engine. The primary is 23mm and the secondary is 27mm and can achieve a 235cfm. These carbs are found on Pinto's, Mustang II's, Vega's. I hope this helps.
Good luck,
Ken
