ok i have plans on increasing th epower of my 200...im going to leave the 200 block stock(no bore for now)...im going to add a aus2v with a holley 2bbl 350 cfm or holley 390 cfm 4 bbl...as for head work i am going to have the 1.75'' intake, 1.50'' exhaust, 3 angle valve job, harden seats and mill the head to get about a 9.6:1 compression so i can still run on pump gas...ill also be adding pretty much everything that is on AZcoupe's pakage "A" deal on his website...as for ignition...mallory unilite dist., msd6al, master blaster 3 coil, msd 8.5 super conducter wires, and accel u groove plugs...the only thing i havent totally agree on getting is a cam?!? i thought a 260H comp cam but i dont know...i do want power but this is also going to be a daily driver and i do want to keep good gas mileage...later plans to take into consideration would be 2500 stall converter, b&m shift kit and oil pan, 9'' rear, 3.55 gear, posi...and for braking power ssb front discs (4lug) and drums in the rear(4lug)...so my real question is what cam would be the best mate for my build-up...if you want to know more info to help me decide...PM me...
gary
gary
