nater200
i went out and started my car yesterday and i heard a whistling sound it would stop if i pull the throttle alittle bit but the when i let the throttle go it started again. so i started searching around the carb and found two holes in the side of the carb that were sucking air they look like they are supposed to have screws in them or vacuum lines. they are right on top of eachother on the left side near the back corner. i believe it is the stock carb. it is a 1980 merc capri. and i was also wordering if any body here has deleted their egr setup if so, do you have the tube and would you be willing to spare it? thanks in advanced.
nater
nater
