Will this work???
Inline6Merc
Head- everything done to it in the Ford Falcon Six Handbook
3 Autolite 1100 carbs
Compression of 10:1
Roller Tiped Rockers
Would these work o wouled i need a hotter cam?
Later,
Curtis
What cam do you got now stock or do you have any specs. if its a stock cam i would think you'll drown the bastard in fuel, cause if im not mistanking i think those autolites are equivlant to like a 125cfm each and 3 of those well thats like 375 cfm i dont think it would handle it to well. you will get crappy gas milage with them it i were you i would swap out to a holley 2300 or a weber carb and kit from cliffy. i did the 2300 swap on my other motor runs like a MOFO nice and gutsy. also if you swap out to that big of fuel system you may definitly want to consider a header swap and a nice scavaging exhaust system, to get the maximum performance out of that mod.
wes
If you are going to do all that and not change the cam, you'll be disappointed. Even a Cam with one 1100 is quite an improvement. With the 3 carbs, definitely get a Cam that will take advantage of it.
Slade
Howdy Curtis and All:
You'll be amazed at the performance difference of the head you've proposed, even without a cam. The Mods you've described will really wake up an engine. The 1100s may not be the best choice for a tri-power. In any case the progressive linkage will help to control the total cfm. I like the little glass-bowled, early Holley #1908s. It takes time and tuning to get a tri carb set-up to run right.
A performance cam will allow the rpm (and power) range to move up to a higher range. The more air you can pump- the more power you can make.
If you're limited to a head mod stage for now, then you've got the right stuff planned. When you get the time/money/need you can build the bottom end, adding a cam and all the other good stuff at that time.
Stage building is a good way to go, IF you can stick to a plan. You've got to plan for the final stage at every stage.
That's my two cents, for what it's worth.
