Spacer height's effective performance is directly relative to intake total volume. Anything over 2" shows no improvement on any of the (all V8) tests I've seen. 2" did out perform 1" on the lower-height smaller intakes. On tall single plane intakes gains stopped at 1". . . All intakes benefitted from the 1", and individual-bore types were better than open, and that was attributed to the improved AFR distribution.Oh, another thing, I was thinking about is the 2v direct mount. @DON has a mounting plate brazed to his log with 2 circular intake openings. Was watching a spacer shootout where they dynoed different spacers on a V8 with the same 4 barrel to see what length effect was as well as spacers with individual holes or with one big opening. The spacers with the individual holes performed better in all ranges and in that particular engine, a 1” spacer performed better than a 2” spacer.
I realize a V8 4 barrel isn’t appples to apples to a small 6 with a modified log but I’m just looking at the overall trend. I think I will attempt to space it a total of 1” including the mount on the log
uempistons.com
It could be as simple as a piece of sheet metal bent with a radius and bonded to the floor of the log below the carb. It could also be done with epoxy putty. Guys used to shape the intake ports on racing heads with epoxy putty.You will have to keep me posted on how you do the deflector part. It is interesting but not sure how it would be fabed
Oh, I was planning on it going in once and never coming out so I’d put it in before the plate is brazed in.Just thinking, whatever it is it has to fit thru the small bore hole that is brazed in the log![]()
I thought that earlier in this thread it was stated that the deflector helped most at high speed. I could be mistaken
Interestingly, the calculated net traction horsepower gain was more pronounced at higher RPM rather than lower RPM. Given measurement limitations, there is some margin of error, but the improvement appears consistent.
Subjectively, drivability is noticeably smoother and more responsive. It is definitely quicker — though not quite Mach-E GT quick.
So many variables though….to the divider that is. Any of them could change the results
Good to know and thanks for the pics. Ford probably had adequate quality control standards for a critical area like this.Well, easier said than done
I took a few pics but hard to see. I put a coat hanger wire in for a reference for size. I marked the wire with a white stroke in the photo. In one you can see the freeze plug on the end. Overall don’t see much that needs work. It’s pretty much like what you can see down the hole. Probably not worth smoothing it out with the effort it would take.
. Some kind of flapper sand paper to run thru the hole on the end? A long porting bit?
