theguitarist
Long story short: Mustang wouldn't start several weeks ago. Replaced the battery and a bad battery cable, still no start. Replaced the starter solenoid, still no start. Tested the solenoid and found no power coming out. Exchanged solenoid for another one that wasn't defective, still no start. Replaced starter, almost nothing. Replaced starter ground strap (the original got a little mangled up when I removed the old starter), still almost nothing.
Here's what I mean by "almost nothing". When I turn the ignition, the battery and solenoid clicks and the starter begins to turn, but it stops after a second. After the starter quits I only get the batery and solenoid chatter but nothing from the starter unless it sits awhile or I unhook the battery cables and start over. The radio and accessories all work fine.
I'm down to two more ideas, but additional input is needed. Maybe the power cable from the battery/solenoid to the starter? How about the alternator?
A long time age I solved the problem of solenoid and voltage regulator mounting.
