I planned on re-reading your EDIS install thread, you made it look easy enough for a guy like me to figure it out.
I've got minimal fabrication skills, but I have no doubt that I'll be able to create the motor and transmission mounts necessary to install the powertrain.
It could be just me, but I think the main reasons that people don't like the motorcycle carbs is the perceived complexity..
Multiple carb mounts
"complicated" linkage
Carburator sync
Sizing a set of carburators for IR performance (I don't even know how you rate them for CFM)
personally I worry that one out of 4 carbs may suffer individual issues and leave a single cylinder exposed to unpleasant fuel mixture, how would I ever know until its too late?
So now that we know I have marginal skills and I'm afraid of multiple carbs..
I've been working on projects and amassing equipment.
I've got a grinder/cut off wheel, a 90amp flux MIG, and I'm buying a cheap chinese plasma from the neighbor (Lotos Cut50D), I also have a 20t press that I'm working on building a brake for, and I recently bought a HF 40lb sandblast cabinet and an Eastwood dual voltage powdercoat gun, with an old oven to cook parts.
For the flange there are a couple options, I could build a 1 off (cut/grind/weld/drill/tap/weld) its been done for generations, just pick an induction (carb style) and forge forward.
If I had dimensions for bolts/ports, I know a guy I could tap to crank out a CNC/DXF/DWG file and have one or more plasma or laser cut, maybe sell a couple to generate some project funds.
I'm pretty good at measuring for precision and knowing when to apply it and when it doesn't matter.
For my skidsteer engine swap I needed a bellhousing plate
Case 1830 Motor swap -- FordSix Forum
I made it out of 1/4" steel, the bellhousing and starter bolts lined up perfectly, the flywheel and starter snout holes are 'good enough'
I'll be reading as many motorcycle carb intake threads as I can find, like this.. (carb and IR EFI)
HOW TO FIT A ZETEC - Part 1 - Fuel System -- TurboSport.co.uk
I've wanted to try making my own intake since I helped get the parts together for clintonvillian to build his 300 MPFI manny
Started on headers and efi intake today! -- FordSix Forum
The intake, header, and throttle body flanges were cut here at work out of 3/8" steel, but we can't cut aluminum (yet) but there is a laser shop here in town that can.
I'd like to try making one out of round stock and another out of formed steel, utilizing a wooden buck and hammering the metal over it.
Since I don't have a permanent car to put it in, I have a couple other for fitting it into. I have a '65 Mustang shell (very rusty, but the engine bay is good)
Any mounts I make for the engine *should* work for a Mustang. I've been meaning to make this car mobile on its own power, but I always thought I'd use the spare 200/C4 that I have sitting on my shop floor out of a '67 Mustang, but since this will eventually be a dedicated project/fun car, I may as well, it isn't doing anything else. And in regards to performance it should be very close to a Falcon, especially since its gutted.
As I was getting ready to finish this post, I realized that the blue Mustang 2 parked in Dad's trees had a running 2.3l, that carb should be a decent starting point for a 2.0L... I may have to go swipe that car.. If it does still run, I could even possibly install the 2.3L then change it out for the zetec.
Carburator sync
