Hole in my log!
Falcongreaser
Hole in my log!
Post #1 by Falcongreaser » Thu Mar 11, 2010 2:33 pm
New to the site here, I have a 61 falcon 2d sadan. I have found a hole about the size of a nickle in my log, right under my carb! Seems to be where all my gas is going. Car seems to run ok though. Was wondering if any of u knew a good fix on this. I can weld, but have nvr welded cast iron before. Was wondering if welding is the only option to fill the hole.
hasa68mustang
Re: Hole in my log!
Post #2 by hasa68mustang » Thu Mar 11, 2010 4:12 pm
Falcongreaser wrote:New to the site here, I have a 61 falcon 2d sadan. I have found a hole about the size of a nickle in my log, right under my carb! Seems to be where all my gas is going. Car seems to run ok though. Was wondering if any of u knew a good fix on this. I can weld, but have nvr welded cast iron before. Was wondering if welding is the only option to fill the hole.
you said it was under your carb as in the bottom of the log? Could it possibly be dropping any gas onto the exhaust manifold?
According to Matt our cars will be elevnty billion times faster than all of yours because our carbs flow 500cfm!!!!
Falcongreaser
Re: Hole in my log!
Post #3 by Falcongreaser » Thu Mar 11, 2010 4:32 pm
Well its actully strait across from the e in firing order on the top of the log, just to the left side of the valve cover. At work atm, but will post a pic when I get home.
350kmileford
Re: Hole in my log!
Post #4 by 350kmileford » Thu Mar 11, 2010 10:17 pm
Any chance it's in the thin casting metal?
Ronbo
Re: Hole in my log!
Post #5 by Ronbo » Fri Mar 12, 2010 5:03 am
Or a missing vacuum T?
2017 F-150 Lariat ECO Boost
2011 F-150 Lariat ECO Boost
68 Mustang, power drums/steering, AC, single outlet coated header, Holley 350, DS II w/Accel super coil
80 Goldwing (half the Mustang :))
fordconvert
Re: Hole in my log!
Post #6 by fordconvert » Fri Mar 12, 2010 8:19 am
Or its a later head with an EGR port? Maybe a damaged egr port?
TJ H
Had a 66 mustang coupe, traded in for a 93 convert 2.3.
73 Eldorado convert 8.2 megasquirt, 80 Eldorado 5.7 diesel, 96 Suburban 6.5TD, 05 Magnum 5.7 hemi.
Bradbutlernc
Re: Hole in my log!
Post #7 by Bradbutlernc » Fri Mar 12, 2010 10:51 am
That sounds like a big problem, how is it running with a vacuum leak that massive? Id also be worried about that chunk being pulled into one of the valves and messing the head up real good. Had that happen with a screw once. :x
1967 Falcon 2 Door
200 Inline 6
3 Speed Auto
Autolite 1100
Flowmaster 40 Dual Exhaust
Falcongreaser
Re: Hole in my log!
Post #8 by Falcongreaser » Fri Mar 12, 2010 11:35 am
It looks to be in a thin part of the log, The car runs great, drove it today 70 for about 30mins no prob. could someone tell me how to find out if it is a lter dated head?
Ronbo
Re: Hole in my log!
Post #9 by Ronbo » Sat Mar 13, 2010 3:55 pm
Dude, dont take this the wrong way but....there is no way you have a hole the size of a nickle and the car is running. Is it a hole you can put a pencil in? (Dont use your finger and dont ask ;)). I'm trying to figure where this "hole" is. Is it a plug, like a freeze plug, of some sort? Where be the picture my brother? ;) That would help millions!
Ron
Falcongreaser
Re: Hole in my log!
Post #10 by Falcongreaser » Mon Mar 15, 2010 12:12 pm
well, a closer look has 2 holes, one on each end of the intake, looks to be some kinda vacume or something. I know nothing about these sixes, my first one. gonna try and post pics once i figure this out
mustang6
Re: Hole in my log!
Post #11 by mustang6 » Mon Mar 15, 2010 3:31 pm
I think you are referring to the casting holes for the intake log, you should have soft/freeze plugs in those. I don't think it would run at all if you didn't have plugs in them.
Scott
Falcongreaser
Re: Hole in my log!
Post #12 by Falcongreaser » Mon Mar 15, 2010 6:29 pm
Falcongreaser
Re: Hole in my log!
Post #13 by Falcongreaser » Mon Mar 15, 2010 6:34 pm
I meant to say there at the top on each end, right next to the valve cover, on both sides of the carb, on top of the log. One hole is dry as a bone, the other is leaking gas. Was wondering if any of u knew if my engine is missing something, such as a T vacume or something as someone has mentioneaction in post above. Any help would be great! Thnx
LaGrasta
Re: Hole in my log!
Post #14 by LaGrasta » Mon Mar 15, 2010 7:03 pm
those holes do not interfere with the internal dimensions at all as they are in between the runners.
1963 1/2 Falcon 170/C4/8" (alt, a/c, Petronix/42v coil/8mm wires, 16" electric fan, electric fuel pump, Holley 1940, K&N Harley air filter, power dual m/c, 11" disc, 3" drop, Shelby drop, white tuck/roll, Moon steering wheel, '59 Caddy tail lights, fishtail exhaust tip, shaved trim, handles, cowl, fuel, dash, 4" radius trunk/door corners, power windows, 600w iPod system)
Frankenstang
Re: Hole in my log!
Post #15 by Frankenstang » Mon Mar 15, 2010 7:12 pm
LaGrasta wrote:those holes do not interfere with the internal dimensions at all as they are in between the runners.
+1 Yep, got a 'couple holes in my head' as well.:lol: ..completely normal.
IIRC they're hook points for the ford specialized tool/engine hoist/boom thingamajig for pulling the engine.
-Robert
66 Mustang 200+30, 67 BH, 89 4cyl T-5, 71 Comet 4 lug 8" 3:1rear, 85 T-Bird v6 DS, 10 Mallory Unilite Hyfire VI-A, 08 Vaporizer 1bbl, 68 Cougar 2" exhuast,65 pipe, 74 Mav man disc m/c & Scarebird(87 Stanza rotors 89 Cavalier calipers), 73 Datsun 240z Appliance Wire Mags, 03 Mustang Leather seats
All in one car! Johnny Cash would be proud...I got it One Piece at a Time
Falcongreaser
Re: Hole in my log!
Post #16 by Falcongreaser » Mon Mar 15, 2010 7:49 pm
ha what a battle for nothing! :roll: Well I got everything stripped off. Pulling the engine tonight, so I can paint her up sat. Gonna take a closer look n see where that gas is comming from. Also wondering if theres a place I can buy some rearend stuff from, shes wining like crazy. Thnx for the info
Mercury Mike
Re: Hole in my log!
Post #17 by Mercury Mike » Tue Mar 16, 2010 2:48 am
What kind of rear end stuff? haha.
And when I had a hole like that that actually WAS where it shouldn't be, I used RTV and the cardboard from the back of the RTV package. Then I drove it another 10,000~ miles like that!
1967 Mercury Monterey "unnamed to date" 390/V8/C6
1965 Mustang Coupe "Sally" 200/6/C4 (Sold)
1962 Falcon Ranchero "Veronika" 170/6/C4 (Lost)
1965 Mustang Coupe "Betty" 200/6/C4
1956 F-100 Big Window "Henry" 272/V8/3ontheTreeOD
1968 Chevy Winnebago 350/th350
1966 Dodge Coronet Magnum 440 V8/Auto 3 Spd (Sold)
1970 Dodge SuperBee 383 V8 (Sold)
Ronbo
Re: Hole in my log!
Post #18 by Ronbo » Tue Mar 16, 2010 5:05 am
Falcongreaser wrote:One hole is dry as a bone, the other is leaking gas.
That right there would be a point of concern! Are you sure it's gas or is it oil coming from the valve cover? Most of us probably have the latter :roll: You could actually (someone stop me here if I'm wrong) thread a short bolt in the hole for appearance purposes? An allen head would look ok in there. Shoot, if someone asks, tell them that was for the nitrous phase you went through. Guaranteed, one of the folks you tell that to will go home and try it! ;) Good luck with your build!
Ron
Falcongreaser
Re: Hole in my log!
Post #19 by Falcongreaser » Wed Mar 17, 2010 9:40 am
I thought it was oil at first, but it does smell like gas. Im not sure about the rear stuff I would need, as I have never worked on one before. I would think changing some gears in there would stop the whining?
Ronbo
Re: Hole in my log!
Post #20 by Ronbo » Thu Mar 18, 2010 5:10 am
Parts for these rears are hard to come by. I have a good spare in my shed so when the current one lets go I can swap. Now if a deal on an 8" pops up the one in the shed will go to e-bay AFTER being offered here. It has the 2.83 gear set so its not that desirable.
Ron
ozconv
Re: Hole in my log!
Post #21 by ozconv » Thu Mar 18, 2010 6:37 pm
http://ratech.stores.yahoo.net/fo7axpa.html
Web address above will get you everything but the ring and pinion which are not available. Not sure, but the wine may be because the other parts are worn and the ring and pinion are no longer properly aligned. Good luck.
Users browsing this forum: bubba22349, chad and 22 guests
