I need to select a better coil for use with a Pertronix 1. I know that the Flamethrower coil is a reasonable choice, but it appears to be toned down for use with factory wiring. I'll be running the pink resistor wire to close a 30 amp fused relay, which will send 12 volts from the starter solenoid to the coil.
Looking in the Summit catalog, much of the specs seem to be on "turn ratio", peak current draw, spark plug voltage, and spark duration.
The specs they list:
MSD Blaster 2/3:
100:1 turn ratio
140 milliamps peak
45,000 volts
350 microsecond spark
Accel Superstock:
113: 1 turn ratio
300 milliamps peak
45,000 volts
400 microsecond spark
PerTronix Flame thrower
115:1 turn ratio
53 milliamps peak
40,000 volts
150 microsecond spark
3 ohm internal ballast (6 cylinder applications)
I can see the potential benefit of the longer and hotter spark, but what are the other considerations? What is the turn ratio all about? Guessing that the Pertronix would be lower performance, but would run cooler than the other two and have less electrical draw. Are there any downsides to running the MSD or Accel coil when triggered by the Pertronix?
John/Fresno
