Hi guys,
Just as the question says, is one approach to increasing compression ratio better than the other, or is pretty much equal either way?
Here is my situation. I have a 250ci. The head was milled in prior work (plus port & polish and 2v conversion). From the stock compression chamber volume of 62cc's the head is now around 51cc's. Up until now the bottom end was untouched. With a Felpro gasket the head milling brought my CR up to around 8.8 from a stock of around 8.2. Better, but not by much. However at the time I didn't want to take the engine out so it was as good as I was going to get.
Now the whole thing is coming out. I'd like to get my compression ratio up to 9.5 or so which seems to be the agreed-upon sweet spot for a mild street vehicle. I have the option of installing the 255ci V8 pistons which are taller than stock pistons (by 0.085"), and that removes a good deal of the deck clearance. However it's actually too much combined with the prior head mill: I calculate if I put the taller pistons in there and do nothing else, my static CR tips the scales at over 11:1, which is too high.
In this post by CZLN6 (David), the expert himself discusses dishing these taller pistons: Click here.
The guy he's talking to has a slightly different situation than me but the principle would still work. I figure I'd need a dish of about 12-14cc's milled into the top of the pistons, depending on the overbore we end up with. Total deck clearance in the end would be about 0.040" (0.125" total deck clearance minus the 0.085" taller height of the new pistons).
Alternatively I could retain the stock pistons and deck the block by some amount to arrive at my desired CR. I couldn't go to Zero Deck because again with the milled head CR would be too high. But I could bring it down some amount, I think about .040" would get me in the range (and would leave a deck clearance of about .085").
Either way I can get to my desired CR. One method involves milling a dish into the piston, another involves machining the surface of the block. One method (dished pistons) ostensibly leaves me with a lower deck clearance, which I think is a good thing. However this is maybe somewhat misleading since the surface of the piston is also dished, which may sort of act like the equivalent of extra deck clearance.
Well, I got to pick one or the other!
Luke
Luke
