I've run both, but it's tough to compare because I had the Weber on a 2-1 adapter on the small log, and then when I swapped to the large log I did a direct mount with the Autolite... so too many other changes to really tell the carb difference. I can say though, that I was never really happy with the 32/36 for low end performance, it was only fun when you floored it. Also it felt like I was constantly messing with jets/tubes, I think you would really need to have a wideband gauge hooked up to get it working well. I tried a 38/38 for a short while too, which had much better low end, but I always had problems getting a good idle with it.
The 2100 was incredibly easy to set up, didn't have to do anything but slightly turn the mix screws after I put it on. I'm going to try some bigger jets eventually, and possibly a Holley power valve to dial it in a little more, but otherwise it drives really well as is.
